[GRASS-user] EVI algorithm
Markus Neteler
neteler at osgeo.org
Sat Jul 14 15:33:37 PDT 2012
(please do "reply-all")
On Fri, Jul 13, 2012 at 10:09 AM, Danut Mihon <danut_mihon at yahoo.com> wrote:
> Hi,
> I am not aware of scaling the images before importing them into GRASS. The
> range for all three inputs in [0, 255].
Where do the maps come from?
> The EVI result is between [-1, 1],
> but here comes the strange part:
> - the areas with rich vegetation have values close to -1
> - the urban areas correspond to higher values (e.g. 0.2)
In fact, unusual and like "reverted".
> It should be the other way around. One solution is to multiply all values
> with -1, but I do not think that this is a general solution. Maybe you have
> some better ideas to guide to.
It does not make much sense because NDVI/EVI do not need any reverting.
> Maybe these seem "silly" questions to you, be I am a novice in GRASS.
Not silly at all. I suspect an input data problem but would need to see
one of these input maps (I worked successfully with MODIS EVI in GRASS).
Markus
