[GRASS-user] dpi output from ps.map
Tom Russo russo at bogodyn.org
Tue Jul 17 16:13:28 PDT 2012
On Fri, Jul 13, 2012 at 09:14:13PM -0400, we recorded a bogon-computron collision of the <nelson.gerald at gmail.com> flavor, containing:
>    We need to have a raster eps or pdf that has a dpi of 300. Reading through
>    the old list entries it appears that ps.map had a hard coded limit of 75
>    dpi.
Have you tried it?  I believe that hard-coded limit was taken out years ago.
(as I recall, I may even have been the person who complained about it on
this list, as I had a big raster I needed to render on a large-format printer,
and this hard-coded limit was in the way.)
In fact, I'm pretty sure that this limitation is long gone.  Look at the
documentation for a current version of ps.map, and it'll tell you that raster
resolution is controlled by the region settings.
What old list entries were you reading?
Tom Russo    KM5VY   SAR502   DM64ux          http://www.swcp.com/~russo/
Tijeras, NM  QRPL#1592 K2#398  SOC#236        http://kevan.org/brain.cgi?DDTNM
"And, isn't sanity really just a one-trick pony anyway? I mean all you get is
 one trick, rational thinking, but when you're good and crazy, oooh, oooh,
 oooh, the sky is the limit!"  --- The Tick
