[GRASS-user] a varriable error!
Albert Saribekyan
albertsaribekyan at rambler.ru
Mon Jul 23 05:24:25 PDT 2012
Albert Saribekyan.
Dear all!!
I wrote a script for r.example module(GRASS-6.4)
here is it:
#!/bin/bash
GISBASE=/localuser/soft/grass-6.4.2RC2/dist.
export GISBASE
PATH=$PATH:$GISBASE/bin:$GISBASE/scripts
export PATH
if [ -z "$LD_LIBRARY_PATH" ]
then
LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$GISBASE/lib
else
LD_LIBRARY_PATH=$GISBASE/lib
fi
export LD_LIBRARY_PATH
GIS_LOCK=$$
THE_GISDBASE="/localuser/soft/grassdataalb"
THE_LOCATION="example"
THE_MAPSET="PERMANENT"
THE_GRASSRC="/tmp/grassrc.$$"
echo "GISDBASE: $THE_GISDBASE
LOCATION_NAME: $THE_LOCATION
MAPSET: $THE_MAPSET
" > "$THE_GRASSRC"
export GISRC="$THE_GRASSRC"
/localuser/soft/grass-6.4.2RC2/dist./bin/r.example
rm "$THE_GRASSRC"
end when I run it there is a following error`
[albert.saribekyan �� ce ~]$ ./script
ERROR: G_getenv(): Variable GRASS_GUI not set
regards,
Albert.
