[GRASS-user] error running command in grass 6.4
William Kyngesburye woklist at kyngchaos.com
Fri Jun 1 07:29:33 PDT 2012
From what I saw in past discussion of this problem, probably the new GRASS 6.4 you installed changed enough that you need to fix your interface program.  Using GRASS libraries in external programs is sensitive to exact GRASS versions.
On May 31, 2012, at 10:04 PM, Janet Choate wrote:
> Hi all,
> (please excuse if i don't use the correct terminology - sorry!)
> i previously had a successful version of grass installed, but just reinstalled grass 6.4 hoping i would get the python gui.  not only did i not get the python gui, but now i get an error when i attempt to run a grass interface program we created that always worked fine with the previous installation.  the error is:
> dyld: lazy symbol binding failed: Symbol not found: _G_gisinit
>  Referenced from: /usr/local/bin/rat
>  Expected in: /Applications/GRASS-6.4.app/Contents/MacOS/lib/libgrass_gis.dylib
> in an internet search i see that others have had the same problem, but Referenced from a different program.  if anyone knows how to fix this problem regarding the lazy symbol binding failed: Symbol not found: _G_gisinit please advise.
> much appreciated!
> Janet
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
