[GRASS-user] r.basin ? for plane geometry of polygon shapefiles
Marco Jorge marco_gjv at ymail.com
Tue Jun 5 07:54:16 PDT 2012
I have 10k small polygons stored in a shapefile and in raster format (nr classes = nr of basins).
I am interested in getting some planar geometry information for each polygon.
I have 3 problems, not considering the lack of knowledge:
- no DTM;
- no channels;
- try to foul r.basin with the shapefile
Can you think of a way to pick the module and its code to calculate the indices in the end of the post?
Can anyone point me a way to pick up the major axis instead of the lenght of the main channel ?
Any hint on major (or minor) axis extraction?
Should I try other approach?
Thanks in advance
Marco
	* The circularity ratio: is the ratio between the area of the basin and the area of the circle having the same perimeter of the basin.
	* The elongation ratio: is the ratio between the diameter of the circle having the same area of the basin and the length of the main channel.
	* The compactness coefficient: is the ratio between the perimeter of the basin and the diameter of the circle having the same area of the basin.
	* The shape factor: is the ratio between the area of the basin and the square of the length of the main channel
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20120605/d9a8fa03/attachment.html>
