[GRASS-user] r.basin: Completes on Some Basins, Fails on Others
Sylvain Maillard
sylvain.maillard at gmail.com
Thu Jun 7 00:48:22 PDT 2012
I get a similar issue some time ago (but with a vector input) and wrote a
little script to work only with raster (no need to transform back to vector)
it's using r.distance (
http://grass.osgeo.org/grass64/manuals/html64_user/r.distance.html), wich
"Locates the closest points between objects in two raster maps" and output
an ascii line with the intersection point ...
you just need to input your 2 raster with basin boundaries and streams, and
it will do the job for all your objects at once ;)
Cheers,
Sylvain
2012/6/6 Rich Shepard <rshepard at appl-ecosys.com>
> Running r.basin using r.to.vect basin boundaries and r.to.vect
> r.stream.extract weighted streams (but same issue using unweighted
> streams).
> So far, of 7 sub-basins on which I've run the module only 4 complete
> successfully. The other three go through the entire process then fail with
> the error message that the outlet needs to be on a stream channel created
> by
> r.stream.extract.
> I use the same protocol on each sub-basin: zoom in very close to where the
> sub-basin boundary and stream channel cross, then note the x, y coordinates
> from the status line on the display window frame.
> What might account for this same process, using the same r.stream.extract
> map, to work on some sub-basins and fail on others?
> Rich
-------------- section suivante --------------
Une pi?ce jointe HTML a ?t? nettoy?e...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20120607/634702da/attachment.html>
