On Thu, 7 Jun 2012, John Ortiz wrote: > If the maps that you want to remove have some (pattern) in the map name, > you could remove it running this loop in the GRASS-Terminal. John, That's essentially what g.mremove does. For example, g.mremove rast="bas*" removes all raster maps beginning with 'bas'. Rich
