[GRASS-user] Attribute transfer from one table to another based on position of vector items
Daniel Lee lee at isi-solutions.org
Fri Jun 8 05:35:41 PDT 2012
Hi Jaromír,
Have you tried v.what.vect? That would probably do the trick :)
Best,
Daniel
B.Sc. Daniel Lee
Geschäftsführung für Forschung und Entwicklung
ISIS - International Solar Information Solutions GbR
Vertreten durch: Daniel Lee, Nepomuk Reinhard und Nils Räder
Softwarecenter 3
35037 Marburg
Festnetz: +49 6421 379 6256
Mobil: +49 176 6127 7269
E-Mail: Lee at isi-solutions.org
Web: http://www.isi-solutions.org
2012/6/8 Jaromír Kamler <kamler at centrum.cz>
> Hi,
> I have two vectors imported from SHP. One contains lines (areas), which
> represents sites and in other are texts with cost of sites. I imported them
> to GRASS. Texts with costs of ground are now points with cost in attribute
> table and I turned circuid lines to the areas with centroids.I need copy
> costs from attribute table of costs to the attribute table of sites vector.
> I have no key for connection of this tables. Only one "key" is their
> position, because points with cost attribute are above corresponding areas.
> One point with cost of ground is above one area. How get cost of
> corresponding point to the corresponding attribute of ground? I do not see
> any simple possibility.
> Thanks for your advices. Best regards.
> J. Kamler
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20120608/74ae2a8b/attachment-0001.html>
