[GRASS-user] r.basin: Completes on Some Basins, Fails on Others
Margherita Di Leo
diregola at gmail.com
Fri Jun 8 08:08:47 PDT 2012
Hi Micha,
On Fri, Jun 8, 2012 at 4:48 PM, Micha Silver <micha at arava.co.il> wrote:
> Hi Madi:
> Regarding the threshold value in your auxilliary parsing.py script, do you
> think it might be better to calcuclate a suggested value from the size of
> the original DEM, rather than just put in some random 10,000 or so.
> Obviously the user has to understand, and change the threshold to suit his
> needs, but if the script is going to contain some value, maybe it should be
> something "reasonable". I thought, for example to choose a suggested thresh
> size of num_cells/100. i.e.:
> N=`r.univar -g | grep "^n=" | cut -d "=" -f 2`
> THRESH=$(( $N / 100))
> Does that sound reasonable? Since the python auxilliary script runs
> independently of GRASS, I'm not sure how how this would all merge together.
> But it's worth thinking about.
I've added comments in the wiki page in the python script section, about
the threshold and the name of the DEM, both parameters should be changed
manually.
For what concerns a "reasonable" value of the threshold, well, it actually
depends on too many factors, by the way, I've provided already some ways to
start from a "reasonable" value (all exposed in the wiki page):
1) r.basin has a flag -a which uses a default value of threshold,
corresponding to 1 km^2 (this value comes from literature and it's suitable
for _italian_ territory, this means that it could be completely wrong for
other territories)
2) r.threshold has a different reasoning. It starts from a relationship
between the slope and the upslope area.
3) r.stream.preview: it simply allow user to have a preview of the
threshold in order to quickly set a "reasonable" value. (this is a piece of
wx.stream, which I'm not satisfied of and am re-writing from scratch).
Anyway, if you think that the wiki page looks confusing, I really
appreciate your help in editing :-)
Thanks,
madi
Dr. Margherita Di Leo
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20120608/b185bc56/attachment.html>
