[GRASS-user] GRASS Session Record
    Glynn Clements
    glynn at gclements.plus.com
    Fri Jun  8 10:08:22 PDT 2012
Rich Shepard wrote:
>    It would be very helpful to capture all GRASS commands and output in a
> text file for each session. I believe this can be done by invoking grass
> with the 'tee' command. Is there another, preferred way to do this?
Use a terminal emulator with a "log to file" capabaility. Or use the
"script" command.
The main problem with "tee" is that it won't work with commands which
require a terminal.
