[GRASS-user] v.surf.rst error: Input window change
Daniel Victoria daniel.victoria at gmail.com
Sun Jun 10 07:48:13 PDT 2012
As an update, if I remove the mask raster option, the interpolation
finishes ok but it gives me the message at the end...
G_ludcmp() failed! n=0  d=0.00
v.surf.rst complete.
Cheers
Daniel
On Sun, Jun 10, 2012 at 11:15 AM, Daniel Victoria
<daniel.victoria at gmail.com> wrote:
> Hi all,
> Using wingrass 7 svn here and I'm seeing an error in v.surf.rst saying
> that the input window changed while reading maps.
> Below is the entire command output. The strip of data I'm
> interpolating is in a diagonal orientation so I believe that's why I'm
> seeing a lot of warnings about "taking too long to find points". I'm
> also using a mask. I believe Carlos Grohmann mentioned the same
> problem back in feb/2011 [1]
> (Sun Jun 10 10:40:11 2012)
> v.surf.rst -z input=ground_11_01 at PERMANENT layer=1 elev=dtm11_daniel
> maskmap=duke_mask at PERMANENT tension=50. smooth=2
> Reading features from vector map ...
> Strip exists with insufficient data
> Ignoring 148872 points (too dense)
> Number of points from vector map 248952
> Number of points being used 100080
> Bitmap mask created
> Processing segments...
> Taking too long to find points for interpolation - please change the
> region to area where your points are. Continuing calculations...
> ERROR: Input window changed while maps are open for read
> (Sun Jun 10 11:06:42 2012) Command finished (26 min 30 sec)
> Cheers
> Daniel
> [1] - http://osgeo-org.1560.n6.nabble.com/v-surf-rst-broken-in-7-0-svn-td3889195.html
