[GRASS-user] VOXEL will not display (3D geological volume modeling)
davidalvarez76
davidalvarezgisfl at gmail.com
Mon Jun 11 07:25:39 PDT 2012
Hello,
I am trying to create a 3D geological volume modeling. I have 5 geology
layers plus a DSM with a surface area covering around 1300 acres each. For
my test I clip a small subset of the area (10 acres) for each layer.
I set up up the g.region and then run the command r.to.raster3elev and I
also try r.to.rast3, but when i try to display the volumes They come empty.
Is there a step that I am missing?
Thank you,
David
View this message in context: http://osgeo-org.1560.n6.nabble.com/VOXEL-will-not-display-3D-geological-volume-modeling-tp4980404.html
Sent from the Grass - Users mailing list archive at Nabble.com.
