[GRASS-user] d.his with wxGUI?
Rich Shepard
rshepard at appl-ecosys.com
Mon Jun 11 09:45:23 PDT 2012
Running d.his from the command line with d.mon x0 open results in the
display of a colorized shaded relief map. That same map displays in greys in
the wxGUI display. Running that command with d.mon closed, and the wxGUI
active throws an error: the module apparently needs to display the result in
d.mon and not the wxGUI.
With the GUI open, typing 'd.his' on the command line brings up the
module's dialog box, Filling in the required 'h_map' and optional 'i_map'
and trying to run the command produces the same error: there's no display
monitor available.
Two questions: Is there a way to create a colorized shaded relief map
(using r.colors does not produce equivalent results) since d.his does not
work with the GUI? Why does the GUI dialog box present if the module cannot
run in this environment?
Rich
