[GRASS-user] VOXEL will not display (3D geological volume modeling)
davidalvarez76 davidalvarezgisfl at gmail.com
Mon Jun 11 17:59:43 PDT 2012
Markus,
For the visualization part i am exporting the voxel into VTK so i can use
Paraview. the result for using the r.to.rast3 or r.to.raster3elev are
always empty.
Thank you,
David
On Mon, Jun 11, 2012 at 4:50 PM, Markus Neteler [via OSGeo.org] <
ml-node+s1560n4980565h53 at n6.nabble.com> wrote:
> On Mon, Jun 11, 2012 at 4:25 PM, davidalvarez76
> <[hidden email] <http://user/SendEmail.jtp?type=node&node=4980565&i=0>>
> wrote:
> > I set up up the g.region and then run the command r.to.raster3elev and I
> > also try r.to.rast3, but when i try to display the volumes They come
> empty.
> Please tell us how you try to visualize...
> - GRASS monitor
> - GRASS wxGUI
> - nVIZ
> - via Paraview
> thanks
> Markus
> grass-user mailing list
> [hidden email] <http://user/SendEmail.jtp?type=node&node=4980565&i=1>
> http://lists.osgeo.org/mailman/listinfo/grass-user
>  If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.n6.nabble.com/VOXEL-will-not-display-3D-geological-volume-modeling-tp4980404p4980565.html
>  To unsubscribe from VOXEL will not display (3D geological volume
> modeling), click here<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4980404&code=ZGF2aWRhbHZhcmV6Z2lzZmxAZ21haWwuY29tfDQ5ODA0MDR8MzE1ODQ2OTI5>
> NAML<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.n6.nabble.com/VOXEL-will-not-display-3D-geological-volume-modeling-tp4980404p4980605.html
Sent from the Grass - Users mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20120611/ed4e534d/attachment.html>
