[GRASS-user] r.stream with svn grass 64
Stephen Sefick
ssefick at gmail.com
Tue Jun 12 06:38:41 PDT 2012
On Tue 12 Jun 2012 08:22:54 AM CDT, Margherita Di Leo wrote:
> Hi Stephen,
> On Tue, Jun 12, 2012 at 3:17 PM, Stephen Sefick <sas0025 at auburn.edu
> <mailto:sas0025 at auburn.edu>> wrote:
> All:
> I have a grass64 svn installation on Ubuntu 10.04 that I have been
> having not problems with for a while. I have been updating the
> installation in the same way as I have been in a while. I have
> written into the script to automatically install the r.stream*
> modules.
> which script do you use?
This is the script that I am using:
#!/bin/bash
sudo -v
#change when major version number changes
grass_dir='grass64_release'
#get latest GRASS Sources
#svn checkout
https://svn.osgeo.org/grass/grass/branches/#releasebranch_6_4
/home/$USER/source/grass/$grass_dir
#get latest grass-addons
#svn checkout https://svn.osgeo.org/grass/grass-addons
/home/$USER/source/#grass/grass-addons
cd /home/$USER/source/grass/grass-addons
svn up
cd /home/$USER/source/grass/$grass_dir
make distclean
svn up
#ubuntu configuration for Grass 6.5
CFLAGS="-g -Wall" ./configure \
--with-libs=/usr/lib64 \
--with-cxx --with-freetype=yes \
--with-postgres=no --with-sqlite=yes --enable-largefile=yes \
--with-tcltk-includes=/usr/include/tcl8.4 \
--with-python=/usr/bin/python2.6-config \
--with-wxwidgets=yes \
--with-nls --enable-largefile \
--with-proj-share=/usr/share/proj \
--with-readline \
--with-cairo
make -j4
#cd /home/$USER/source/grass/grass-addons/raster
#sudo cp -rf r.stream* /home/$USER/source/grass/$grass_dir/raster
#cd /home/$USER/source/grass/$grass_dir/raster
#make r.stream* modules
#folders=$(ls | grep r.stream)
#for k in $folders ; do
#cd $k
#sudo make -j4
#done
sudo make install
> I have recently, last night, noticed that these are not being
> built and the error -
> ERROR: Incompatible library version for module. You need to
> rebuild GRASS
> or untangle multiple installations.
> This happens to me sometimes when I forget to run make distclean
> before re-compiling the addons.
> HTH,
> madi
> Dr. Margherita Di Leo
