José wrote: > I need to obtain this format from shapefile, how do I? > ESRI ASCII Grid Format r.out.arc but shapefiles are vector data model and Arc ASCII grids are raster data model, so you would have to translate between the two with v.to.rast or v.out.ascii+r.in.xyz, or interpolate with v.surf.* first. Hamish
