[GRASS-user] PS.MAP order of layers
Thomas, Timothy (IFPRI) T.S.Thomas at cgiar.org
Thu Jun 14 08:20:52 PDT 2012
Thanks for your helpful suggestions!  I used "masked y" as my initial solution.  After doing that, I discovered that I wanted the points under some layers and over other layers, so I solved that next problem by using "masked y" for the layers that I wanted it on top of. Ultimately, I think using the pre-selecting points idea will be the most elegant solution, but I have not had time yet to implement that.  I do agree with Anna's suggestion that it would be more natural to treat point vectors like area or line vectors in regard to their order.  In the shorter-term, perhaps re-wording the manual might be helpful.
Thanks again for your help!
   Tim
Timothy S. Thomas, Research Fellow, IFPRI
t.s.thomas at cgiar.org       +1-202-862-4605     skype: timothy.s.thomas      Rm 5035
-----Original Message-----
From: Anna Kratochvílová [mailto:kratochanna at gmail.com]
Sent: Thursday, June 14, 2012 3:18 AM
To: Hamish
Cc: Thomas, Timothy (IFPRI); grass-user at lists.osgeo.org
Subject: Re: [GRASS-user] PS.MAP order of layers
On Thu, Jun 14, 2012 at 7:27 AM, Hamish <hamish_b at yahoo.com> wrote:
> Timothy wrote:
>> I am using rasters, areas, borders, and points in an eps file using
>> ps.map.  I want the points to be placed under an area layer, because
>> I only want the relevant points to a specific country to be seen.
>> Not matter what order I put the commands in (vpoints before or after
>> varea), the points appear on top.  I am running GRASS 6.4 in the
>> Linux environment.
>> Any thoughts on what to do to make this work?
> add "masked y" to the vpoints instruction.
> (the help page for ps.map is somewhat misleading about what the masked
> instruction really does, and if the ordering works among different
> feature types)
I haven't noticed it before. In my point of view it's a bug. Either the help page or better ps.map should be changed. Ordering seems to work for areas and line layers so is there any reason why point layers behave in a different way?
Anna
> #spearfish example
> g.region -d
> ps.map out=test.ps << EOF
> raster elevation.dem
> vareas fields
>  end
> vpoints archsites
>  masked y
>  end
> end
> EOF
> gv test.ps
> as a last resort you can use v.select to crop out the non- overlapping
> points (maybe use its geos op=disjoint option or invert the area with
> v.in.region+v.overlay first); or try v.overlay on its own for "point
> not in polygon".
> Hamish
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
