[GRASS-user] Projection Confusion
Rich Shepard rshepard at appl-ecosys.com
Fri Jun 15 16:14:36 PDT 2012
On Fri, 15 Jun 2012, Hamish wrote:
> n.b. lat,lon is y,x; note also the use of the +proj=latlong
> alias instead of the true +proj=longlat setting,
Hamish,
   Ah, I hadn't noticed this when I first used the cs2cs script. I'll make
that change.
> ... and finally if you look at the option description in the cs2cs man
> page -r only swaps the expected input order.
   I completely forgot about this. It's been many months since I last used
the tool and I just replaced coordinate sets for the current need.
Thanks,
Rich
