[GRASS-user] Add up several maps, which hold different regions, with mapcalc
Paulo van Breugel
p.vanbreugel at gmail.com
Mon Jun 18 04:54:22 PDT 2012
First set the region to fit all maps, like suggested by Marcello. Then,
use r.patch to combine the maps.
Cheers,
Paulo
On 06/18/2012 01:36 PM, Marcello Gorini wrote:
> Büro Seling said:
> My problem begins, when I now try to add up all these single maps
> into one larger map.
> I searched for a solution and tried several things, but nothing
> worked.
> Any tipps or hinds?
> Hey,
> As always, there is probably a much more elegant solution to this
> problem, but this should get you going for now:
> > g.region
> rast=map1,map2
> # just to make sure your region encompass everything
> > r.mapcalc
> "bigmap=if(isnull(map1),99999,map1)+if(inull(map2),99999,map2)"
> # replace nulls on the fly by a specific value that your data does not
> contain
> > r.mapcalc
> "bigmap=if(bigmap==99999,null(),bigmap)"
> # put back the nulls
> Well, ugly like all my codes, but it works.
> Cheers,
> Marcello.
> This body part will be downloaded on demand.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20120618/b5c65097/attachment.html>
