[GRASS-user] Add up several maps, which hold different regions, with mapcalc
Büro Seling
buero-seling at t-online.de
Mon Jun 18 05:07:17 PDT 2012
Am 18.06.2012 12:55, schrieb Büro Seling:
> Dear Group,
> I could not find a way to add up several maps, which hold different
> regions, with mapcalc.
> Within a larger GRASS location (i.e. 80x80 km) I have to make several
> viewshed/line-of-sight analyses.
> Each one with a radius of 5000 meters.
> In the end,with mapcalc, I have to add up all these single maps into
> one map which then contains the information in which place how many
> items can be seen.
> So fare no problem.
> Then I had the idea to spare time and do the viewshed/line-of-sight
> analyses within a smaller region (5000x5000m, just the area I need for
> the single calcuations).
> Also up to now no Problem.
> My problem begins, when I now try to add up all these single maps into
> one larger map.
> I searched for a solution and tried several things, but nothing worked.
> Any tipps or hinds?
> Thx
> Stefan
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Thx Marcello and Paulo,
I will test the Marcellos solution and let You know if it worked!
Thanks again
Stefan
