[GRASS-user] r.threshold: Where is the output?
Helmut Kudrnovsky hellik at web.de
Thu Jun 21 06:33:14 PDT 2012
>>Do I run r.mapcalc on the accumulation map to replace negative values with
> >   zeros? Or, is there a different preferred approachu?
>you can use abs function of r.mapcalc
would the -a flag of r.watershed be an option?
http://grass.osgeo.org/grass64/manuals/html64_user/r.watershed.html
-a
    Use positive flow accumulation even for likely underestimates.[...]
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/r-threshold-Where-is-the-output-tp4982835p4983000.html
Sent from the Grass - Users mailing list archive at Nabble.com.
