[GRASS-user] r.threshold: Where is the output?
Rich Shepard
rshepard at appl-ecosys.com
Thu Jun 21 09:47:24 PDT 2012
On Thu, 21 Jun 2012, Margherita Di Leo wrote:
> Threshold value should be determined by trial and errors. If you have a
> map of digitized streams ("real" streams) you can compare the results you
> get using different threshold values and see which gives you the most
> similar to the reality.
madi,
That confirms what I thought I would do.
> For what concerns your shell script running r.basin in loop for several
> basins, I'd suggest to analyze the "problematic basin" separately (outside
> the loop) adjusting the coordinates of the output by hand.
Also what I planned. Thanks for confirming.
Regards,
Rich
