[GRASS-user] wms import fail
Andres Kuusk
andres at aai.ee
Fri Jun 22 06:20:47 PDT 2012
I have also trouble with r.in.wms.
Estonian Land Board has a WMS server http://kaart.maaamet.ee/wms/alus,
projection of maps EPSG:3301.
I am using GRASS-7.0.svn, r52182, openSUSE-11.4, linux 2.6.37.6-0.11-pae.
In the graphical user interface wxGUI the connect to server returns error
message:
File "/usr/local/grass-7.0.svn/scripts/r.in.wms", line 284, in <module>
sys.exit(main())
File "/usr/local/grass-7.0.svn/scripts/r.in.wms", line 228, in main
list_layers()
File "/usr/local/grass-7.0.svn/scripts/r.in.wms", line 223, in
list_layers
cap_xml.getLayers()
File "/usr/local/grass-7.0.svn/etc/r.in.wms/wms_parse.py", line 78, in
getLayers
print " Title: " + ly['title']
UnicodeEncodeError: 'ascii' codec can't encode character u'\xf5' in
position 10: ordinal not in range(128)
However, I got the list of layers - two items. Now, if I select a layer
(of10000 - ortofoto) and connect, I got the same error message again, and
nothing happens.
In the commandline in the xterm window where I started GRASS the results
are different.
% env
TERM=xterm
SHELL=/bin/tcsh
LANG=en_US.utf8
PYTHONSTARTUP=/etc/pythonstart
HOME=/home/grass/CHRIS_LE/CHRIS
MACHTYPE=i586
GISBASE=/usr/local/grass-7.0.svn
GRASS_VERSION=7.0.svn
PYTHONPATH=/usr/local/grass-7.0.svn/etc/python
GRASS_PAGER=more
GRASS_WISH=wish
GRASS_PYTHON=python
GRASS_GNUPLOT=gnuplot -persist
GRASS_PROJSHARE=/usr/local/share/proj
GRASS_HTML_BROWSER=xdg-open
GISDBASE=/home/grass
% g.region -p
projection: 99 (Lambert Conformal Conic)
zone: 0
datum: wgs84
ellipsoid: a=6378137 es=0.006694380022900787
north: 6468300
south: 6468050
west: 693060
east: 693315
nsres: 1
ewres: 1
rows: 250
cols: 255
cells: 63750
% r.in.wms mapserver=http://kaart.maaamet.ee/wms/alus -l
returns the long list of map layers, there is a layer
LAYER: of10000
Title: ORTOFOTO
SRS: EPSG:3301
I have tried all possible combinations of r.in.wms options.
% r.in.wms output=p_orto mapserver=http://kaart.maaamet.ee/wms/alus
layers=of10000 srs=EPSG:3301 format=tiff maxcols=255 maxrows=250
method=near --overwrite
Calculating tiles...
ERROR: r.tileset failed
In the directory /home/grass/wms_download/ an empty directory p_orto was
created.
Adding the option -p results in a different error message:
% r.in.wms -p output=p_orto mapserver=http://kaart.maaamet.ee/wms/alus
File "/usr/local/grass-7.0.svn/scripts/r.in.wms", line 284, in <module> sys.exit(main())
File "/usr/local/grass-7.0.svn/scripts/r.in.wms", line 245, in main
request = wms_request.WMSRequest(flags, options)
File "/usr/local/grass-7.0.svn/etc/r.in.wms/wms_request.py", line 28, in __init__
self.__set_options()
File "/usr/local/grass-7.0.svn/etc/r.in.wms/wms_request.py", line 40, in __set_options
self.srs_scale = int(grass.parse_key_val(proj_srs['+to_meter']))
NameError: global name 'proj_srs' is not defined
The same error messages I get using r.in.wms options -c, -g, -a.
Do I something wrong or is there some error in the r.in.wms ?
The native reolution of the ortophoto at WMS server is 0.25 m, I guess.
I tried the region resolution of 0.25, and missed maxcols and maxrows
values in the commandline as well but no success.
In February 2010 using some GRASS-6 version I could download small pices
of ortophoto from this WMS server.
Thanks for any assistance.
Andres Kuusk
Tartu Observatory, Estonia
andres at aai.ee
