[GRASS-user] r.mapcalc: collection of values
Glynn Clements
glynn at gclements.plus.com
Tue Jun 26 11:56:01 PDT 2012
bei wrote:
> I am trying to create a map combining two maps. Each category in the final
> map will depend on the value in the other two. I will do it using nested
> "if". I have already done this kind of "if":
> aed06_p_3= if(a06_p_2 == 243, if(arb_p >= 20, 10, if(arb_p < 10, 20,
> 33)), if(a06_p_2 == 244, if(arb_p >= 20, 10, if(arb_p < 10,
> 31, 33)), if(a06_p_2 == 324, if(arb_p >= 20, 10, if(arb_p <
> 10, 32, 33)), a06_p_2)))
> But now, instead of one value for a06_p_2 I will have various possible
> values (more than 5), so the nested if is geeting too long.
> I would like to know if there is an option shorter than writting a
> collection of "OR": a06_p_2==243 | a06_p_2==234 | a06_p_2==245 |
> a06_p_2==246
> a way to collect all the values, maybe something similar to a06_p_2 IN
> (243,244,245,246)
There isn't an "in" operator.
Also, from your description, you might be better off using r.cross and
r.reclass.
