[GRASS-user] Importing ASCII file
Daniel Lee
lee at isi-solutions.org
Wed Jun 27 23:30:31 PDT 2012
Rainer,
Good idea. Here's the output of gdalinfo:
gdalinfo prec_1.asc
Driver: AAIGrid/Arc/Info ASCII Grid
Files: prec_1.asc
Size is 43200, 18000
Coordinate System is `'
Origin = (-180.000000000000000,90.000000000000000)
Pixel Size = (0.008333333333333,-0.008333333333333)
Corner Coordinates:
Upper Left (-180.0000000, 90.0000000)
Lower Left (-180.0000000, -60.0000000)
Upper Right ( 180.0000000, 90.0000000)
Lower Right ( 180.0000000, -60.0000000)
Center ( 0.0000000, 15.0000000)
Band 1 Block=43200x1 Type=Int32, ColorInterp=Undefined
NoData Value=-9999
So it looks like Arc/Info ASCII grid is correct.
Hamish,
you're right, editing the cell size even with vi would be painful. I
wouldn't be afraid to name names about the software, but the fact of the
matter is that I don't know what software it is. I downloaded the data from
http://www.ccafs-climate.org/data/
In any case, using the -l flag did the trick! Thanks a ton, that makes my
day :) Case closed!
Best,
Daniel
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20120628/5932fea8/attachment.html>
