[GRASS-user] v.select usage
    Rich Shepard
    rshepard at appl-ecosys.com
    Thu Jun 28 09:02:05 PDT 2012
   I want to identify which point features are within each sub-basin and
v.select looks like the appropriate module. However, I must not be using it
properly.
   The example on the manual page has the 'a' map as the points
(firestations) and the 'b' map as the area. When I replicate this with my
data all I see are all the points. For example,
   v.select ain=drillholes bin=catchments out=holesbybasin op=overlap
the resulting map is a duplicate of the drillholes map. Adding the map types
reveals that the 'a' map must be the area since point is not an acceptable
map type in this location. So, I submit,
   v.select ain=catchments atype=area bin=drillholes btype=point \
and the resulting map has only the catchments to display and in the
attribute table. Changing the operator in this second attempt to 'contains'
makes no difference to the result: only the catchments and their numbers are
in the output map.
   What I need is a list of point IDs grouped by the catchment number. How do
I use v.select to produce this outcome? Or, is this not the appropriate
module to find the solution to points-in-polygons?
TIA,
Rich
