[GRASS-user] Correct import of a global grid (0E to 360E) to GRASS (-180W to 180E).
Daniel Lee
lee at isi-solutions.org
Sat Jun 30 04:05:45 PDT 2012
Hi Marcello,
It sounds like you're trying to import your map into the wrong coordinate
system. If you have the correct coordinate system of the NetCDF, you should
be able to define a location with that CRS using either the correct EPSG
code or a WKT string. If need be, you can always create a WKT string as
well, although I don't know how to do that.
Best,
Daniel
B.Sc. Daniel Lee
Geschäftsführung für Forschung und Entwicklung
ISIS - International Solar Information Solutions GbR
Vertreten durch: Daniel Lee, Nepomuk Reinhard und Nils Räder
Softwarecenter 3
35037 Marburg
Festnetz: +49 6421 379 6256
Mobil: +49 176 6127 7269
E-Mail: Lee at isi-solutions.org
Web: http://www.isi-solutions.org
2012/6/30 Marcello Gorini <gorini at gmail.com>
> Dear all,
> I am pretty sure this must be easy, but I just can't find the correct
> answer.
> My grid is a netcdf geographic grid that spans from 0E to 360E and from
> 90N to -90S.
> I use r.in.gdal to import it, but it gets flipped since GRASS region spans
> from -180W to 180E.
> How to do it right?
> Thanks in advance.
> Best regards,
> Marcello.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20120630/3752f2d9/attachment.html>
