[GRASS-user] Definintion of cleanup in pyhton script
Johannes Radinger JRadinger at gmx.at
Thu Mar 1 06:08:54 EST 2012
Hi GRASS users,
maybe someone can help me with the cleanup process in a
GRASS python script I am writing. The script uses the
gparser functionality to get the needed files etc via
the GUI.
I also try to include a proper cleanup process within
the script which deletes all the tmp maps created. This
should also work if the script stops (e.g due to an error).
So I think I FIRST need to define all the files which
should be removed. The problem is that my script includes
a while loop (iteration) so I can't really say which
files will be created in advance. How can I define a proper
cleanup in such cases?
The script looks at the moment like:
#!/usr/bin/env python
import grass.script as grass
tmp_rast = None
tmp_vect = None
def cleanup():
	if (tmp_rast):
		grass.run_command("g.remove",
				rast = tmp_map_rast,
				quiet = True)
def main():
	max_count = 5 # maximum number of iterations
	#global variables for cleanup - standard values
	global tmp_rast
	tmp_rast = [f + str(os.getpid()) for f in
		(["r%d_tmp_" % x for x in range(max_count+1)]+
		["rt%d_tmp_" % x for x in range(max_count+1)]+
		["r_diff%d_tmp_" % x for x in range(max_count+1)])]
	diff = 9999
	while (diff is not None):
	#In this while loop all the tmp-files are created
if __name__ == "__main__":
	options, flags = grass.parser()
	atexit.register(cleanup)
	sys.exit(main())
How can I improve this? Maybe someone of you is more experienced than I am.
Thank you so much!
Best regards,
Johannes
NEU: FreePhone 3-fach-Flat mit kostenlosem Smartphone!
Jetzt informieren: http://mobile.1und1.de/?ac=OM.PW.PW003K20328T7073a
