[GRASS-user] Replace 0 by NULL in categorial raster map
Johannes Radinger
JRadinger at gmx.at
Mon Mar 5 09:56:04 EST 2012
-------- Original-Nachricht --------
> Datum: Fri, 02 Mar 2012 20:22:30 +0100
> Von: Moritz Lennert <mlennert at club.worldonline.be>
> An: Johannes Radinger <JRadinger at gmx.at>
> CC: grass-user at lists.osgeo.org
> Betreff: Re: [GRASS-user] Replace 0 by NULL in categorial raster map
> On 02/03/12 15:56, Johannes Radinger wrote:
> > Just for my personal interest two questions: 1) What if I want to
> > replace the category "0" with NULL (not the values 0)
> Category 0 = value 0.
sorry I meant the category named (with label) "0".
> Raster values in GRASS are called categorie values.
> Or maybe I don't understand what you mean ?
> > 2) What would be the correct module if I want to assign another
> > category than NULL to certain values? Is hat module r.category? And
> > how can that be used in pyhton (how are the rules supplied)? Eg.
> > assign all values greater than 0 to 1 all other values NULL.
> If you have a integer values (CELL), then r.reclass.
As I have a CELL raster I'd like to use r.reclass. In my special
case I want to assign a Category labeled "1" to all values 1 and want to replace all 0 by NULL. (No other values present only 0 an 1). For the NULL-task I use r.null, and for the 1-task r.reclass.
But how can I simply use a rule in when calling r.reclass in a python script???
grass.run_command("r.reclass",
input = "in",
output = "out",
rules = ???)
/Johannes
> If you have floating point values, generally r.recode is more
> appropriate (or just multiply your floating point map by the appropriate
> number to make it integer).
> Moritz
NEU: FreePhone 3-fach-Flat mit kostenlosem Smartphone!
Jetzt informieren: http://mobile.1und1.de/?ac=OM.PW.PW003K20328T7073a
