[GRASS-user] Possible bug in r.sum and in r.stats?
Rainer M Krug r.m.krug at gmail.com
Tue Mar 6 10:11:54 EST 2012
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi
I get the following output as seen on the screenshot.
My setup:
one mapset PERMANENT (linked), one mapset in which the map is,
executed from mapset ANALYSIS.
$R@$MS is
HSericea_seedsPlant_2037 at HakSim.279.edited.tar.gz.CapePeninsula.CapePeninsula.none-12
Look at the number of cells in r.stats, compared to total cells as
given by r.info (which is correct).
Any ideas what is happening? I want to calculate the sum of the same
map in 500 different mapsets, so I am using this approach.
Any input welcome,
Rainer
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel :       +33 - (0)9 53 10 27 44
Cell:       +33 - (0)6 85 62 59 98
Fax :       +33 - (0)9 58 10 27 44
Fax (D):    +49 - (0)3 21 21 25 22 44
email:      Rainer at krugs.de
Skype:      RMkrug
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAk9WKTgACgkQoYgNqgF2egp6swCeOstKZfNu31bjam578AZWrXNi
+nMAnRP9HD5yhh2/BotB44ZUjPxnCh2n
=MQEU
-----END PGP SIGNATURE-----
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20120306/8ab27ac9/screen-0001.png
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20120306/8ab27ac9/screen.png-0001.obj
