[GRASS-user] Re: spgrass6
Dylan Beaudette debeaudette at ucdavis.edu
Tue Mar 6 16:32:43 EST 2012
On Wednesday, February 22, 2012, Paolo Cavallini wrote:
> Il 22/02/2012 15:54, Roger Bivand ha scritto:
> > Using the improved raster graphics handling for square cells with image()
> > rather than spplot() and useRaster=TRUE - equivalent to
> > image.SpatialGridDataFrame() and useRasterImage=TRUE with the same matrix
> > takes 1.2 seconds on x11/cairo. You didn't say which version of R you are
> > using - the raster graphics facilities have been improved recently.
> 2.14.1-1 on Debian testing.
> > Did you try using image() instead of spplot() if your cells are square,
and
> > if rasterImage() is available in your version of R?
> Yes, image() is resonably fast, but misses automatic legend, etc.
> Thanks a lot for your reply.
> Paolo Cavallini
> See: http://www.faunalia.it/pc
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Check out the plot() function from the raster package, or the related
rasterViz (?) package. They have some neat stuff in there.
Roger already mentioned this, but I'll add a little more. Now that we have
powerful computers and nice packages like spgrass6 it is very simple to load
large raster files into R without much effort. However, just because we can
fit a linear model on that massive stack of pixels doesn't mean that one
should. This is even more important with regard to plotting functions. I have
found that coarsening the region resolution a bit before loading in raster
that only need to be plotted helps considerably.
If you really must work with stacks of large grids, the best approach I have
found is the raster package.
Cheers,
Dylan
Dylan E. Beaudette
USDA-NRCS Soil Scientist
California Soil Resource Lab
http://casoilresource.lawr.ucdavis.edu/
