[GRASS-user] Possible bug in r.sum and in r.stats?
Rainer M Krug
r.m.krug at gmail.com
Thu Mar 8 04:43:40 EST 2012
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 07/03/12 21:20, Glynn Clements wrote:
> Rainer M Krug wrote:
>> I get the following output as seen on the screenshot.
> In future, please copy/paste the text rather than using a screenshot.
I wanted to, but it was completely garbled due to line breaks:
I now changed the wraplength setting (thunderbird -
http://forums.mozillazine.org/viewtopic.php?f=29&t=1598995), and it would have looked fine.
>> Look at the number of cells in r.stats, compared to total cells as given by r.info (which is
>> correct).
>> Any ideas what is happening?
> Does the current region match the raster? r.info displays statistics for the underlying raster;
> the data which r.stats uses is resampled and cropped/padded according to the current region.
Thanks a lot - that is the problem - the wind file was different. Fixed it and it is working now.
As some commands do use the region and mask, while others don't, it might be a good idea to make
this clear in the manual - I know, it is stated if they do, but not if they don't.
An sub-section under the Description might be an option?
Cheers,
Rainer
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys.
(Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax : +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer at krugs.de
Skype: RMkrug
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAk9Yf0wACgkQoYgNqgF2egq6mgCfb6AzJXqW9nSVnDOc9JdH31dR
D+gAn37fhHZp/Jkfn/TJEZvy0CqTKmoI
=dbyd
-----END PGP SIGNATURE-----
