[GRASS-user] r.region for intersection with vector map?
    Micha Silver
    micha at arava.co.il
    Sun Mar 11 14:29:13 EDT 2012
Wouldn't the simpledt be to convert the vector to a raster named MASK, then
r.mapcalc analyticalrast=dem will give you a raster only in the analytical
region
Micha Silver
052-366-5918
-----Original message-----
To: grass-users at lists.osgeo.org
Sent: Sun, 11 Mar 2012, 18:35:50 GMT+02:00
Subject: [GRASS-user] r.region for intersection with vector map?
   I've used v.overlay for its set intersection ability to save features
only
within the boundary of another vector map. Can I use r.region to do the same
operation on raster maps?
   Specifically, I have two huge (about 51G each) DEM maps and I need only
the region within the project's analytical boundary. The analytical boundary
is a vector polygon map.
   If I run
 	r.region map=dem_east vect=analytical_boundary
the raster map's region is that of the vector map. But, I don't believe that
this removes all cells beyond that region.
   Advice on how to eliminate the extraneous cells (and clip the raster to
the nearest cell boundaries of the vector map) is greatly appreciated.
TIA,
Rich
grass-user mailing list
grass-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-user
This mail was received via Mail-SeCure System.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120311/0381d9da/attachment.html
