[GRASS-user] Re: r.region for intersection with vector map?
Hermann Peifer
peifer at gmx.eu
Mon Mar 12 06:48:37 EDT 2012
On 12/03/2012 10:13, Moritz Lennert wrote:
> On 12/03/12 05:57, Hermann Peifer wrote:
>> On 12/03/2012 00:16, Helmut Kudrnovsky wrote:
>>> but r.region defines the extent of the whole raster map.
>> Why would one want to do this, compared to leaving the extent as
>> detected during import?
> Use cases might be:
> - the file you import is not georeferenced, but you have elsewhere the
> information about where the corners should be
> - your file was incorrectly georeferenced with a constant shift
> And probably others...
Aha. Thanks.
I usually fix this type of issues (if any) before importing, by
gdal_translate'ing the source file int vrt format which has the correct
corners, etc., then I import the vrt file.
Hermann
