[GRASS-user] nviz: Multiple Vector Maps Draped on Raster DEM
Juan David Rondón Dí­az juda87 at yahoo.com
Wed Mar 14 14:05:14 EDT 2012
On 14/03/12 12:47, Rich Shepard wrote:
>   From a thread a couple of months ago I learned that nviz will allow
> only a
> single vector map to be draped over the raster base map. For presentation
> purposes using ps.map I need multiple vector maps to be displayed on the
> raster map.
>   Is the best approach to use v.overlay (with the union/OR option) to
> create
> a single vector map that can be incorporated with the raster DEM with
> nviz?
> Or, is there a better approach?
> TIA,
> Rich
> grass-user mailing list
> grass-user en lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-user
No, actually you can load more vector layers over a raster map using nviz
for example you can type
/nviz elevation=dem vect=streets,streams
and you will be loading two vector layers (streets and streams) over a
raster dem map.
If you have nviz already loaded you have to go to Visualize/Lines 3D
Polygons or Points and use "New" button. To switch the layer
configuration just pick the button with name of the layer in front of
"Current".
Juan David Rondón Díaz
Tesista de Ingeniería Ambiental
Universidad Distrital Francisco José de Caldas
openSUSE.org <http://www.opensuse.org>
------------ próxima parte ------------
Saltado el tipo de contenido multipart/related
