[GRASS-user] Re: i.vi.mpi
Alexander Muriy amuriy at gmail.com
Thu Mar 15 02:42:23 EDT 2012
Hello Ripsime.
This is my Makefile
> MODULE_TOPDIR = /usr/local/grass-6.4.2svn/
> CC=mpicc --static
> PGM = i.vi.mpi
> LIBES = $(GISLIB) $(GMATHLIB)
> DEPENDENCIES = $(GISDEP) $(GMATHDEP)
> include $(MODULE_TOPDIR)/include/Make/Module.make
> ifneq ($(USE_LARGEFILES),)
>  EXTRA_CFLAGS = -D_FILE_OFFSET_BITS=64
> endif
> default: cmd
> CC=mpicc -L/usr/local/grass-6.4.2svn/lib/ /usr/local/grass-6.4.2svn/lib/
> libgrass_gis.6.4.2svn.so
> When I do a make I am getting this:
> make[2]: *** [/usr/local/grass-6.4.2svn/man/man1/i.vi.mpi.1] Error 126
> make[2]: Leaving directory `/localuser/ripsime/mpitest'
> make[1]: *** [mancmd] Error 2
> make[1]: Leaving directory `/localuser/ripsime/mpitest'
> make: *** [cmd] Error 2
You ignored these compilation errors and want the working module ...
Why not to use the default Makefile from <i.vi.mpi> add-on directory? I
used command:
"make MODULE_TOPDIR=/home/user/bin/grass643svn_bin/grass-6.4.3svn/"
and i.vi.mpi compiled successfully.
So try to recompile module and than run you script again.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120315/25610ab8/attachment-0001.html
