[GRASS-user] Why Does Re-projection Increase Disk Space Used?
	[UPDATE]
    Rich Shepard
    rshepard at appl-ecosys.com
    Thu Mar 15 11:06:11 EDT 2012
On Thu, 15 Mar 2012, Glynn Clements wrote:
> Which OS?
   Linux.
> r.proj calls remove() on the temporary file immediately after opening it.
> On Unix, that removes the directory entry, and will cause the file itself
> to be deleted as soon as r.proj terminates. On Windows, the remove() call
> will fail (you can't delete an open file on Windows), and the file will be
> left behind.
   For some reason, then, it's not working here. Slackware-13.1/x486 and
-13.37/x86_64.
   On the latter host I found two files in ../.tmp/<hostname>/: <pid>.1 and
<pid>.2. The former was almost 100G in size and the latter was >10G. The
source raster file is 45M in size.
Thanks, Glynn,
Rich
