[GRASS-user] Re: TIN (Linear interpolation) from points
    TheGeographer
    dalura86 at googlemail.com
    Sat Mar 17 11:15:00 EDT 2012
Vincent Bain wrote
>> @Vincent: I need linear triangulation.
> Yes, this is what r.surf.nnbathy does. In other words, you obtain a
> faceted surface where triangles summits meet input points.
Ok, but i use vector points as input data. And the module needs a raster
map.
Are the interpolation results very different between linear interpolation
and natural neighbor?
The r.surf.nnbathy uses only natural neighbor as interpolation method.
View this message in context: http://osgeo-org.1560.n6.nabble.com/TIN-Linear-interpolation-from-points-tp4627723p4628159.html
Sent from the Grass - Users mailing list archive at Nabble.com.
