[GRASS-user] i.vi.mpi grass7
    Ripsime Khachatryan
    kuli13 at mail.ru
    Mon Mar 19 07:22:51 EDT 2012
Hi all
I executed the following command:
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/home/soft/grass7/grass-7.0.svn/lib
 to export the library of grass, then I check it and it was their :
 LD_LIBRARY_PATH=/opt/d-cache/dcap/lib:/opt/d-cache/dcap/lib64:/opt/glite/lib:/opt/glite/lib64:/opt/globus/lib:/opt/lcg/lib:/opt/lcg/lib64:/opt/classads/lib64/:/opt/c-ares/lib/:/home/soft/grass7/grass-7.0.svn/lib:/home/soft/grass7/grass-7.0.svn/lib:/home/soft/grass7/grass-7.0.svn/lib/libgrass_raster.7.0.svn.so
So all is right !!!
But I have this error again:
/home/soft/grass7/grass-7.0.svn/bin/i.vi.mpi: error while loading shared libraries: libgrass_raster.7.0.svn.so: cannot open shared object file: No such file or directory
p0_22498: p4_error: Child process exited while making connection to remote process on wn1.yerphi-cluster.grid.am: 0
p0_22498: (4.281250) net_send: could not write to fd=4, errno = 32
So please any suggestion or help
Regards,
Ripsime
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120319/8fd95730/attachment.html
