[GRASS-user] windows format for temporary file path
    Glynn Clements
    glynn at gclements.plus.com
    Tue Mar 20 02:03:39 EDT 2012
Richard Edmonds wrote:
> Ok this is very strange, my script is very small 30 odd lines, using the
> correct convention I still get an error. Here's a script with ONLY the
> offending commands as follows with the subsequent error:
> v.to.rast --overwrite input=$GIS_OPT_INPUT_VECTOR output=$TMPLAYER1 use=attr column=elevation
> g.remove rast=$TMPLAYER1
> Removing raster <v.myscript.tmp.1564>
> raster: couldn't be removed
> is it related to the fact I'm running winGRASS?
Probably. There seems to be a problem with the database drivers on
WinGRASS:
	http://trac.osgeo.org/grass/ticket/1276
	http://trac.osgeo.org/grass/ticket/1579
