[GRASS-user] Raster map Calculator
Michiel Kunzel mich_kun at hotmail.com
Tue Mar 20 04:46:04 EDT 2012
Solved!
I don't know whether this was the region, it seemed set valid, re-set it just to be sure.
Gave the same confusing result at first, but might have been the color table set wrong.
The results appeared to be integer with just one value, but resetting the colour table and performing a stretch gave readable results.
Thank you for your help.
Michiel
> Date: Tue, 20 Mar 2012 09:13:35 +0100
> From: mlennert at club.worldonline.be
> To: mich_kun at hotmail.com
> CC: grass-user at lists.osgeo.org
> Subject: Re: [GRASS-user] Raster map Calculator
> On 19/03/12 20:42, Michiel Kunzel wrote:
> > Hello list,
> > I am trying to create a series of ratio images using grass 6.4.1 and I
> > can't get the syntax for the raster calculator figured out.
> > What I've got at the moment is:
> > 'Bar45rastfl = 1.0 * BarB40 at PERMANENT / BarB50 at PERMANENT'
> > I've tried varying the equation above but to no avail. The resulting
> > maps do not contain any values.
> > What am I doing wrong?
> Have you set your region correctly ?
> I.e. g.region rast=BarB40
> before running r.mapcalc ?
> Moritz
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120320/983713a7/attachment-0001.html
