[GRASS-user] NetCDF rotated pole
Eduardo Klein
eklein at usb.ve
Wed Mar 21 10:51:11 EDT 2012
Michael,
Thanks a lot for the instructions. It worked perfectly on my files!
Saludos, EKS
On 03/20/2012 05:42 PM, Michael Barton wrote:
> Edwardo,
> I am attaching a PDF and RTF of the workflow I used to import paleocurrent data from a NetCDF file with rotated poles. While it may not exactly match your file, it should give you an idea of how to proceed. Let me know how it comes out.
> Michael
> On Mar 20, 2012, at 6:18 AM, Eduardo Klein wrote:
>> Thanks Michael, your advice will be much appreciated!.
>> Saludos, EKS
>> On 03/19/2012 04:39 PM, Michael Barton wrote:
>>> I'm at NCAR right now and I'm doing that very thing today in fact.
>>> Once I have an answer as to the difference between TLAT and ULAT, and TLONG and ULONG within the NetCDF files, I'll be able to give you a full work flow for this.
>>> Michael
>>> On Mar 19, 2012, at 2:44 PM,<grass-user-request at lists.osgeo.org> wrote:
>>>> Message: 3
>>>> Date: Mon, 19 Mar 2012 13:20:33 -0430
>>>> From: Eduardo Klein<eklein at usb.ve>
>>>> Subject: [GRASS-user] NetCDF rotated pole
>>>> To: grass-user at lists.osgeo.org
>>>> Message-ID:<4F6771E9.2080301 at usb.ve>
>>>> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
>>>> Hi,
>>>> Is there any way to read a NetCDF file which has a rotated pole Mercator
>>>> projection and have it inside GRASS with the North pole at North?
>>>> I'm trying to use AVISO SSH products on GRASS 6.4.1 and gdal 1.8.0
>>>> Thanks!
>>>> Eduardo Klein
>>>> Lab Sensores Remotos e
>>>> Instituto de Tecnolog?a y Ciencias Marinas
>>>> Universidad Sim?n Bol?var
>>>> Caracas, Venezuela
>>>> ph (58) (212) 906-3111 ext 6700
>>>> fax (58) (212( 906-3111 ext 6701
>>> _____________________
>>> C. Michael Barton
>>> Visiting Scientist, Integrated Science Program
>>> National Center for Atmospheric Research&
>>> University Corporation for Atmospheric Research
>>> 303-497-2889 (voice)
>>> Director, Center for Social Dynamics& Complexity
>>> Professor of Anthropology, School of Human Evolution& Social Change
>>> Arizona State University
>>> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
>> Eduardo Klein
>> Instituto de Tecnología y Ciencias Marinas
>> Universidad Simón Bolívar
>> Caracas, Venezuela
> C. Michael Barton
> University Consortium for Atmospheric Research
Eduardo Klein
Caracas, Venezuela
