[GRASS-user] intersection between two lines vector to obtain
points
Daniel Lee
lee at isi-solutions.org
Wed Mar 21 18:34:12 EDT 2012
Hi there,
Am 21. März 2012 19:05 schrieb Micha Silver <micha at arava.co.il>:
> On 03/21/2012 06:46 PM, Pierluigi De Rosa wrote:
> Hi
> I'm looking for a procedure to get a point vector obtained as
> intersection of two vector layer.
> You can do this with a two step procedure. First patch the two line
> vectors together with v.patch. Then run v.clean using the "error=..."
> option. It's not so intuitive, but the "errors" output vector holds the
> topology "errors". In the case of patching two line vectors, this will be
> all the intersection points that v.clean creates when building topology.
> (Note that it's theoretically possible that the two vectors will have an
> intersection exactly on a node, and then this node will not be in the
> errors output vector. But if the line vectors are independant, this is
> highly unlikely)
> I want to have the same output of v.overlay (option and) but for two
> line vector. So I need as geometry points located exactly at the
> intersection of two layers and attribute table as spatial joint of the
> two attribute table.
> This method will find the intersections between the two line vectors, but
> it *does not* combine the attribute tables. Only the attribs from the first
> table listed in v.patch are included.
Afterwards you could also use v.distance to grab the attributes from the
second table. The manual for v.distance has some examples that could be
used almost 1-1.
Cheers,
Daniel
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120321/4fe6ec5d/attachment.html
