[GRASS-user] Re: TIN (Linear interpolation) from points
TheGeographer
dalura86 at googlemail.com
Thu Mar 22 06:59:24 EDT 2012
Hi community,
I'm trying to convert my 3 vector points to raster points. The aim is to use
this raster points as input for r.surf.nnbathy.
I created a region with following command:
g.region --verbose vect=gfa_niep_work at PERMANENT nsres=1 ewres=1
This is the output of the region:
projection: 99 (Transverse Mercator)
zone: 0
datum: potsdam
ellipsoid: bessel
north: 5699460
south: 5698740
west: 3328920
east: 3329940
nsres: 1
ewres: 1
rows: 720
cols: 1020
cells: 734400
In the next step I used v.to.rast with following commands:
v.to.rast --overwrite --verbose input=gfa_niep_work at PERMANENT type=point
output=gfa_niep_rast use=attr column=werte
The metadata are these:
| Layer: gfa_niep_rast at PERMANENT Date: Thu Mar 22 11:49:26 2012
| Mapset: PERMANENT Login of Creator: danny
| DataBase: /home/danny/GIS
| Title: Labels ( gfa_niep_rast at PERMANENT )
| Timestamp: none
| Type of Map: raster Number of Categories: 0
| Data Type: DCELL
| Rows: 720
| Columns: 1020
| Total Cells: 734400
| Projection: Transverse Mercator
| N: 5699460 S: 5698740 Res: 1
| E: 3329940 W: 3328920 Res: 1
| Range of data: min = 5.89 max = 5.89
| Data Source:
| Vector Map: gfa_niep_work at PERMANENT in mapset PERMANENT
| Original scale from vector map: 1:1
| Data Description:
| generated by v.to.rast
| Comments:
| v.to.rast input="gfa_niep_work at PERMANENT" layer=1 type="point" outpu\
| t="gfa_niep_rast at PERMANENT" use="attr" column="werte" value=1 rows=4\
| 096
My problem is now that i get only 1 raster point with the value 5.89 instead
of 3 points.
The correct range of the values should be min: 1.853 max: 5.89
What did i wrong?
Cheers
View this message in context: http://osgeo-org.1560.n6.nabble.com/TIN-Linear-interpolation-from-points-tp4627723p4644182.html
Sent from the Grass - Users mailing list archive at Nabble.com.
