[GRASS-user] Re: TIN (Linear interpolation) from points
Daniel Lee
lee at isi-solutions.org
Thu Mar 22 09:26:26 EDT 2012
Hi Danny,
Theoretically that should be fine. I doubt that your points are less than a
meter apart. To tell the truth, I'd need to take a look at the data a bit
more to be able to say much more about it. Your command looks fine to me.
You could also try expanding the region by a hundred meters or so, just to
take a look at whether the points perhaps aren't being converted because
they're right on the edge of your raster. I honestly don't think that'd do
it, but it would be an easy experiment that I would try.
Daniel
B.Sc. Daniel Lee
Geschäftsführung für Forschung und Entwicklung
ISIS - International Solar Information Solutions GbR
Vertreten durch: Daniel Lee, Nepomuk Reinhard und Nils Räder
Deutschhausstr. 10
35037 Marburg
Festnetz: +49 6421 379 6256
Mobil: +49 176 6127 7269
E-Mail: Lee at isi-solutions.org
Web: http://www.isi-solutions.org
ISIS wird gefördert durch die Bundesrepublik Deutschland, Zuwendungsgeber:
Bundesministerium für Wirtschaft und Technologie aufgrund eines Beschlusses
des Deutschen Bundestages, sowie durch die Europäische Union,
Zuwendungsgeber: Europäischer Sozialfonds.
Zusätzliche Unterstützung erhält ISIS von dem Entrepreneurship Cluster
Mittelhessen, der Universität Marburg, dem Laboratory for Climatology and
Remote Sensing und dem GIS-Lab Marburg.
Am 22. März 2012 14:09 schrieb Danny Luque Ramirez <dalura86 at googlemail.com>
> Hi Daniel,
> this steps i've tried already :D
> This is very confusing, one time i got 2 of 3 points (the points were
> coloured like raster points). And when i try another configuration i got no
> points just a white area with min/max value of one point.
> The extent was always on my vector point map, i think a resolution of 1mx1m
> is ok?
> Danny
> http://osgeo-org.1560.n6.nabble.com/TIN-Linear-interpolation-from-points-tp4627723p4644569.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120322/d40d5dce/attachment.html
