[GRASS-user] Re: v.out.ogr: Convert Attribute Database?
Helmut Kudrnovsky hellik at web.de
Thu Mar 22 16:35:22 EDT 2012
>Used v.out.ogr to export from dbf to a postgres table
v.out.ogr - Converts GRASS vector map to one of the supported OGR vector
formats.
v.out.ogr export the entire vector map (geometry and attribute) not only the
attribute table
from the manual:
http://grass.osgeo.org/grass64/manuals/html64_user/v.out.ogr.html
Export to PostgreSQL/PostGIS
Export areas from GRASS vector map directly to PostGIS:
v.out.ogr input=polygons type=area \
          dsn="PG:host=localhost dbname=postgis user=postgres" \
          olayer=polymap format=PostgreSQL
> v.out.ogr in=surface_h2o
>type=point dsn="PG:dbname=buckhornmine"
missing format definition?
default format is shape-file
what I would do (a very lazy way):
- create a new mapset
- using db.connect (Prints/sets general DB connection for current mapset and
exits.) to define postgres as the mapset database backend
- g.copy surface_h2o to the new mapset and the attribute table should be
automagically in the postgres
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/v-out-ogr-Convert-Attribute-Database-tp4645995p4646386.html
Sent from the Grass - Users mailing list archive at Nabble.com.
