[GRASS-user] About Flood, Erosion and hydrological modelling
Daniel Lee
lee at isi-solutions.org
Fri Mar 23 07:23:08 EDT 2012
Sadly, the entry deadline for GSoC projects for this year is already past,
but perhaps there's some other possibility if you're wanting to get it done
this year.
Best,
Daniel
B.Sc. Daniel Lee
Geschäftsführung für Forschung und Entwicklung
ISIS - International Solar Information Solutions GbR
Vertreten durch: Daniel Lee, Nepomuk Reinhard und Nils Räder
Deutschhausstr. 10
35037 Marburg
Festnetz: +49 6421 379 6256
Mobil: +49 176 6127 7269
E-Mail: Lee at isi-solutions.org
Web: http://www.isi-solutions.org
ISIS wird gefördert durch die Bundesrepublik Deutschland, Zuwendungsgeber:
Bundesministerium für Wirtschaft und Technologie aufgrund eines Beschlusses
des Deutschen Bundestages, sowie durch die Europäische Union,
Zuwendungsgeber: Europäischer Sozialfonds.
Zusätzliche Unterstützung erhält ISIS von dem Entrepreneurship Cluster
Mittelhessen, der Universität Marburg, dem Laboratory for Climatology and
Remote Sensing und dem GIS-Lab Marburg.
Am 23. März 2012 09:35 schrieb Venkatesh Raghavan <
raghavan at media.osaka-cu.ac.jp>:
> Dear All,
> Doing a bit of work with tram in Vietnam using HEC-RAS and
> HEC-GeoRAS. It would be nice to have a GRASS interface to
> HEC-RAS. HEC-GeoRAS below is an interface for ArcGIS.
> Perhaps a project for some student or Google Summer of Code?
> HEC-RAS
> http://www.hec.usace.army.mil/**software/hec-ras/<http://www.hec.usace.army.mil/software/hec-ras/>
> HEC-GeoRAS
> http://www.hec.usace.army.mil/**software/hec-ras/hec-georas.**html<http://www.hec.usace.army.mil/software/hec-ras/hec-georas.html>
> I have also included some other modelling tools related to
> flood/hydrology, erosion etc. Perhaps you know most of it already.
> In future, it may be world considering
> how some of these models can be put to work together to
> bring out more comprehensive output of physical processes.
> For example there is already some work on integrating HEC-RAS with
> MODFLOW.
> https://publicwiki.deltares.**nl/display/OPENMI/Workshops+**
> on+integration+of+the+HEC-RAS+**and+MODFLOW+models+using+**OpenMI<https://publicwiki.deltares.nl/display/OPENMI/Workshops+on+integration+of+the+HEC-RAS+and+MODFLOW+models+using+OpenMI>
> Fully conservative coupling of HEC-RAS with MODFLOW to simulate
> stream–aquifer interactions in a drainage basin
> http://www.sciencedirect.com/**science/article/pii/**S0022169408000772<http://www.sciencedirect.com/science/article/pii/S0022169408000772>
> Surface Water-Groundwater Software Coupling
> http://www.groundwater-**conference.uci.edu/files/**
> Chapter4/2008_conf_Fenske,%**20J.pdf<http://www.groundwater-conference.uci.edu/files/Chapter4/2008_conf_Fenske,%20J.pdf>
> Development of integrated MODFLOW HEC-RAS model using OpenMI
> http://code.google.com/p/**rasmodflow/<http://code.google.com/p/rasmodflow/>
> Flood/Hydrological Modelling
> ICHARM, Japan
> http://www.icharm.pwri.go.jp/
> Integrated Flood Analysis System (IFAS)
> http://www.icharm.pwri.go.jp/**research/ifas/index.html<http://www.icharm.pwri.go.jp/research/ifas/index.html>
> BASINS (Better Assessment Science Integrating point & Non-point Sources)
> http://water.epa.gov/scitech/**datait/models/basins/index.cfm<http://water.epa.gov/scitech/datait/models/basins/index.cfm>
> Kinematic runoff and erosion model KINEROS
> http://www.tucson.ars.ag.gov/**kineros/<http://www.tucson.ars.ag.gov/kineros/>
> GIS and Distributed Watershed Models II
> http://digitalcommons.unl.edu/**cgi/viewcontent.cgi?article=**
> 1466&context=usdaarsfacpub&**sei-redir=1&referer=http%3A%**
> 2F%2Fwww.google.com%2Furl%**3Fsa%3Dt%26rct%3Dj%26q%3Dhec-**
> ras%2520grass%2520gis%**26source%3Dweb%26cd%3D6%26ved%**
> 3D0CEYQFjAF%26url%3Dhttp%253A%**252F%252Fdigitalcommons.unl.**
> edu%252Fcgi%252Fviewcontent.**cgi%253Farticle%253D1466%**
> 2526context%253Dusdaarsfacpub%**26ei%3DO31mT5j_H_HsmAWtw4G5CA%**26usg%**
> 3DAFQjCNEyfNWNrpn8XB73bGz8lAN8**ZipR2A#search=%22hec-ras%**
> 20grass%20gis%22<http://digitalcommons.unl.edu/cgi/viewcontent.cgi?article=1466&context=usdaarsfacpub&sei-redir=1&referer=http%3A%2F%2Fwww.google.com%2Furl%3Fsa%3Dt%26rct%3Dj%26q%3Dhec-ras%2520grass%2520gis%26source%3Dweb%26cd%3D6%26ved%3D0CEYQFjAF%26url%3Dhttp%253A%252F%252Fdigitalcommons.unl.edu%252Fcgi%252Fviewcontent.cgi%253Farticle%253D1466%2526context%253Dusdaarsfacpub%26ei%3DO31mT5j_H_HsmAWtw4G5CA%26usg%3DAFQjCNEyfNWNrpn8XB73bGz8lAN8ZipR2A#search=%22hec-ras%20grass%20gis%22>
> Best
> Venka
> ______________________________**_________________
> grass-user mailing list
> http://lists.osgeo.org/**mailman/listinfo/grass-user<http://lists.osgeo.org/mailman/listinfo/grass-user>
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120323/c60f741d/attachment-0001.html
