[GRASS-user] Re: TIN (Linear interpolation) from points
Danny Luque Ramirez
dalura86 at googlemail.com
Fri Mar 23 07:38:31 EDT 2012
Hi Community,
step by step I'm getting to my goal
Now I've tried to install the nnbathy utility to use it with r.surf.nnbathy.
Well the compilation worked out and nnbathy is now avaibale under
/usr/local/bin .
I've put the shell script r.surf.nnbathy into my addon folder:
/home/danny/interpolation
And it is also executable.
When im trying do start the interpolation process, nothing happens.
I use following command line:
r.surf.nnbathy input=gfa_niep_rast output=delaunay_niep_nn alg=l
When I try to get the help of nnbathy --help nothing happens,too.
What could i have done wrong? Any ideas?
Cheers,
Danny
View this message in context: http://osgeo-org.1560.n6.nabble.com/TIN-Linear-interpolation-from-points-tp4627723p4648296.html
Sent from the Grass - Users mailing list archive at Nabble.com.
