[GRASS-user] About Flood, Erosion and hydrological modelling
Wolf Bergenheim
wolf+grass at bergenheim.net
Fri Mar 23 15:50:49 EDT 2012
Hi Venka,
That seems to an interesting thing. I find it especially interesting since
it's from the same people who originally developed GRASS. Perhaps they
would be willing to co-mentor. Anyways Venka, do you have any information
on how it works together with ARC? I mean would it be possible to get it to
work with GRASS without modifying anything but GRASS?
--Wolf
On Fri, Mar 23, 2012 at 09:35, Venkatesh Raghavan <
raghavan at media.osaka-cu.ac.jp> wrote:
> Dear All,
> Doing a bit of work with tram in Vietnam using HEC-RAS and
> HEC-GeoRAS. It would be nice to have a GRASS interface to
> HEC-RAS. HEC-GeoRAS below is an interface for ArcGIS.
> Perhaps a project for some student or Google Summer of Code?
> HEC-RAS
> http://www.hec.usace.army.mil/**software/hec-ras/<http://www.hec.usace.army.mil/software/hec-ras/>
> HEC-GeoRAS
> http://www.hec.usace.army.mil/**software/hec-ras/hec-georas.**html<http://www.hec.usace.army.mil/software/hec-ras/hec-georas.html>
> I have also included some other modelling tools related to
> flood/hydrology, erosion etc. Perhaps you know most of it already.
> In future, it may be world considering
> how some of these models can be put to work together to
> bring out more comprehensive output of physical processes.
> For example there is already some work on integrating HEC-RAS with
> MODFLOW.
> https://publicwiki.deltares.**nl/display/OPENMI/Workshops+**
> on+integration+of+the+HEC-RAS+**and+MODFLOW+models+using+**OpenMI<https://publicwiki.deltares.nl/display/OPENMI/Workshops+on+integration+of+the+HEC-RAS+and+MODFLOW+models+using+OpenMI>
> Fully conservative coupling of HEC-RAS with MODFLOW to simulate
> stream–aquifer interactions in a drainage basin
> http://www.sciencedirect.com/**science/article/pii/**S0022169408000772<http://www.sciencedirect.com/science/article/pii/S0022169408000772>
> Surface Water-Groundwater Software Coupling
> http://www.groundwater-**conference.uci.edu/files/**
> Chapter4/2008_conf_Fenske,%**20J.pdf<http://www.groundwater-conference.uci.edu/files/Chapter4/2008_conf_Fenske,%20J.pdf>
> Development of integrated MODFLOW HEC-RAS model using OpenMI
> http://code.google.com/p/**rasmodflow/<http://code.google.com/p/rasmodflow/>
> Flood/Hydrological Modelling
> ICHARM, Japan
> http://www.icharm.pwri.go.jp/
> Integrated Flood Analysis System (IFAS)
> http://www.icharm.pwri.go.jp/**research/ifas/index.html<http://www.icharm.pwri.go.jp/research/ifas/index.html>
> BASINS (Better Assessment Science Integrating point & Non-point Sources)
> http://water.epa.gov/scitech/**datait/models/basins/index.cfm<http://water.epa.gov/scitech/datait/models/basins/index.cfm>
> Kinematic runoff and erosion model KINEROS
> http://www.tucson.ars.ag.gov/**kineros/<http://www.tucson.ars.ag.gov/kineros/>
> GIS and Distributed Watershed Models II
> http://digitalcommons.unl.edu/**cgi/viewcontent.cgi?article=**
> 1466&context=usdaarsfacpub&**sei-redir=1&referer=http%3A%**
> 2F%2Fwww.google.com%2Furl%**3Fsa%3Dt%26rct%3Dj%26q%3Dhec-**
> ras%2520grass%2520gis%**26source%3Dweb%26cd%3D6%26ved%**
> 3D0CEYQFjAF%26url%3Dhttp%253A%**252F%252Fdigitalcommons.unl.**
> edu%252Fcgi%252Fviewcontent.**cgi%253Farticle%253D1466%**
> 2526context%253Dusdaarsfacpub%**26ei%3DO31mT5j_H_HsmAWtw4G5CA%**26usg%**
> 3DAFQjCNEyfNWNrpn8XB73bGz8lAN8**ZipR2A#search=%22hec-ras%**
> 20grass%20gis%22<http://digitalcommons.unl.edu/cgi/viewcontent.cgi?article=1466&context=usdaarsfacpub&sei-redir=1&referer=http%3A%2F%2Fwww.google.com%2Furl%3Fsa%3Dt%26rct%3Dj%26q%3Dhec-ras%2520grass%2520gis%26source%3Dweb%26cd%3D6%26ved%3D0CEYQFjAF%26url%3Dhttp%253A%252F%252Fdigitalcommons.unl.edu%252Fcgi%252Fviewcontent.cgi%253Farticle%253D1466%2526context%253Dusdaarsfacpub%26ei%3DO31mT5j_H_HsmAWtw4G5CA%26usg%3DAFQjCNEyfNWNrpn8XB73bGz8lAN8ZipR2A#search=%22hec-ras%20grass%20gis%22>
> Best
> Venka
> ______________________________**_________________
> grass-user mailing list
> http://lists.osgeo.org/**mailman/listinfo/grass-user<http://lists.osgeo.org/mailman/listinfo/grass-user>
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120323/f7453a5f/attachment.html
