[GRASS-user] Installing GRASS 6.4.2 on Ubuntu
John Ortiz
eljhonjhon at hotmail.com
Sun Mar 25 12:58:10 EDT 2012
> I'm trying to install GRASS 6.4.2 on Ubuntu. However when I launch GRASS it
> says it is version 6.4.1. Any ideas what I'm doing wrong?
You are right, the only reason is that grass 6.4.2 still are not available
in Ubuntu repositories..
In this moment if you want grass 6.4.2 version in Ubuntu, you should download the
source code from here:
http://grass.osgeo.org/download/software.php
Download this file:
grass-6.4.2.tar.gz
and compile the source code. The instruction to do it, is here:
http://grass.osgeo.org/wiki/Compile_and_Install
Regards
John Ortiz
Geologist
Smithsonian Tropical Research Institute.
Panama
> Using this URL...
> I clicked on the 'Ubuntu' link in the 'Stable 6.4.2' section.
> However the page it takes me to says it is an unstable version so I dont
> know if this is a faulty link...
> https://launchpad.net/~ubuntugis/+archive/ubuntugis-unstable
> In the package list it includes "6.4.1-2~oneiric1"
> I'm not sure what this means. Does it mean version 6.4.1 to 6.4.2 are
> included and if so is there a way to select which one to install?
> I gave the above ago and following the instructions...
> I uninstalled a previous version of GRASS and then I typed this into the the
> console:
> sudo add-apt-repository ppa:ubuntugis/ubuntugis-unstable
> sudo apt-get update
> sudo apt-get install grass
> grass
> I'm using Ubuntu 11.10 64-bit. I need a 64-bit version of GRASS for memory
> reasons.
> Thanks.
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Installing-GRASS-6-4-2-on-Ubuntu-tp4653599p4653599.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120325/46a9749b/attachment.html
